Witam wszystkich siedziałem ostatnio w aucie i włączyłem test abs :/ udało mi się go jakoś przeprowadzić ale nadal nie działa mi ESP ...
oto moje błędy :
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 159137 km
Time Indication: 0
Date: 2122.14.18
Time: 19:27:55
Freeze Frame:
Count: 3
Count: 2
Count: 4096
Count: 295
Count: 43264
Count: 0
Count: 0
Count: 0
01279 - Longitudinal Acceleration Sensor (G251)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 1048575 km
Time Indication: 0
Date: 2122.14.18
Time: 19:30:53
Freeze Frame:
Count: 7
Count: 2
Count: 4096
Count: 212
Count: 43520
Count: 0
Count: 0
Count: 0
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 1048575 km
Time Indication: 0
Date: 2122.14.18
Time: 19:30:53
Freeze Frame:
Count: 7
Count: 2
Count: 4096
Count: 211
Count: 43520
Count: 0
Count: 0
Count: 0
02085 - Incorrect Control Module Installed
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 1048575 km
Time Indication: 0
Date: 2122.14.18
Time: 19:30:53
Freeze Frame:
Count: 7
Count: 2
Count: 4096
Count: 204
Count: 43520
Count: 0
Count: 0
Count: 0
01486 - System Function Test Activated <----- to nie aktualne
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 1048575 km
Time Indication: 0
Date: 2122.14.18
Time: 19:30:53
Freeze Frame:
Count: 7
Count: 2
Count: 4096
Count: 320
Count: 43520
Count: 0
Count: 0
Count: 0
Nie działa ESP
- Auto: Scirocco+Golf
- Engine: SB+CBDB
- Localization: Szczecin
Re: błąd ESP
Daj fragment skanu z kodowaniem ABSu i numerem pompy, wygląda że musisz zrobić adaptację G85 i chyba pompa nie obsługuje Hill Holda a o zakodowałeś.
mclukas
- Auto: golf 6
- Engine: 2.0 TDI
- Localization: DE
Re: błąd ESP
już wszystko rozpracowałem
dzięki za odpowiedz
pozdrawiam
pozdrawiam
- Baster
- Auto: VW Golf 6 +TOUAREG
- Localization: SZWECJA
Re: błąd ESP
mclukas pisze:już wszystko rozpracowałemdzięki za odpowiedz
pozdrawiam
Jak już rozpracowałeś i problem rozwiązany to mile widziane było by dokładne opisanie rozwiązanie problemu.
Będzie to przydatne dla potomnych
mclukas
- Auto: golf 6
- Engine: 2.0 TDI
- Localization: DE
Re: błąd ESP
Wyłączenie Hill Hold-a i przeprowadzenie adaptacji czujnika G251 i G85
wszystko w opcji ABS w vcds
