Nie działająca wycieraczka tył
kamil880510
Auto: Golf 6 GTI
Engine: 2.0 TSI CCZB
Localization: Radom
Post autor: kamil880510 »
Koledzy nie działa mi tylna wycieraczka, nie wiem gdzie mam zaczac szukać przyczyny, wydaje mi sie że nie ma pradu we wtyczce na klapie, ma ktoś jakiś pomysł?
Wrzucam autoscan mojego auta:
Tuesday,21,July,2015,18:56:42:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWZZZ1KZBW072934 License Plate:
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 25 2E 42 44 46 47 52 55 56
69 76
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0040
Revision: AAH18--- Serial number:
Coding: 0403000C1C070160
Shop #: WSC 01357 011 00200
VCID: E7DB4DC7D6EF8626BAD-80B2
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 000 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93018 km
Time Indication: 0
Date: 2003.14.08
Time: 16:57:56
Freeze Frame:
RPM: 759 /min
Load: 19.2 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 43.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.589 V
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 143B600D892900FC281406E7911D0041310800
Shop #: WSC 80093 222 69422
VCID: 7BF381B7FA67B2C6CE5-802E
No fault code found.
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 7EF588A3E175A7EEE9B-802B
1 Fault Found:
9481200 - Coolant Pressure
B10AB F0 [009] - Too Low
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Date: 2003.14.10
Time: 18:43:28
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 48480A3A8837F30044880080044B092447750088736D8D60648000200040
VCID: 38795EBB8BD159DE637-806D
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 18081 26 0512
Coding: 009795
Component: RLS 170810 05 54 0403
Coding: 0330AD
4 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Time Indication: 0
Date: 2003.14.10
Time: 18:43:27
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 153
Mileage: 93127 km
Time Indication: 0
Date: 2003.14.10
Time: 18:43:53
Freeze Frame:
Term 15 On
Voltage: 14.00 V
ON
ON
Term 50 Off
OFF
ON
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Time Indication: 0
Date: 2003.14.10
Time: 18:45:12
Freeze Frame:
Term 15 On
Voltage: 12.80 V
ON
ON
Term 50 Off
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Time Indication: 0
Date: 2003.14.10
Time: 18:45:12
Freeze Frame:
Term 15 On
Voltage: 12.80 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5K0 919 475 C HW: 5K0 919 475
Component: PARKHILFE 8K H07 0008
Revision: -------- Serial number: 12941023127864
Coding: 110103
VCID: 3665508381C5AFAE71B-8063
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0070
Revision: 00000000 Serial number: 12081006050001
Coding: 000180
VCID: 275B8DC7566FC626FAD-8072
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA3EF2N
Coding: 00003132
ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B7341B7B2E772C68E5-806E
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME37471256ZZZS
Crash sensor for side airbag; passenger side:
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME6D34565EZZZ7
Crash sensor for side airbag; rear driver side:
Serial number: 3512QSME124D4B0AZZZ-
Crash sensor for side airbag; rear passenger side:
Serial number: 3522QSME2C524C43ZZZ-
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JH4000PR
Coding: 5892140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 76E59083C945EFAEB1B-8023
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0034222
Coding: 830000
2 Faults Found:
227379 - Windshield Wiper Switch
B1145 07 [009] - Mechanical Failure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Date: 2003.14.10
Time: 18:43:28
227387 - Windshield Wiper Switch
B1145 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Date: 2003.14.10
Time: 18:43:28
Part No SW: 5K6 920 871 HW: 5K6 920 871
Component: KOMBI H04 0406
Serial number: 00000000000000
Coding: 170B01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: F1EF239F202B4896E49-80A4
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 040810F1002168
Coding: EDA91F4E10021200000000
VCID: EDD73FEFF413AC76C01-80B8
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Time Indication: 0
Date: 2003.14.10
Time: 18:43:33
Component: IMMO H04 0406
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADD34F30DFDBB4EA53-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668505402
Coding: 010000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2149
Coding: 0000052
VCID: 3363699752B7BA86565-8066
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 184 3001
Revision: 00H17000
VCID: 316F639FA8AB8896249-8064
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218109099957
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: E7DB4DC71EEF8626BAD-80B2
1 Fault Found:
9463827 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Date: 2003.14.10
Time: 18:43:30
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Component: Tuer-SG 009 2117
Coding: 0004406
3 Faults Found:
00940 - Mirror Adjust Motor; Passenger Side (V150)
012 - Electrical Fault in Circuit
00110 - Right Mirror Turn Signal Lamp (L132)
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1444956
VCID: 34616A8B57B9BDBE4FF-8061
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: ID-R fehlt
Component: AFS-Lst.-Modul r ....
Coding: 00000255
5 Faults Found:
02234 - Right Headlight Power Output Stage (J668)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 153
Mileage: 93127 km
Time Indication: 0
Date: 2003.14.10
Time: 18:43:28
Freeze Frame:
Voltage: 11.93 V
Speed: 0.0 km/h
ABS 1
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K8263544
Coding: 0101000001
VCID: 65C7C7CF6CE31436081-8030
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H07 0100
Revision: 3A001001 Serial number: 00000132531529
Coding: 410D000100000000
VCID: 3069669B63A1819E2B7-8065
End ---------------------------------------------------------------------
