Kusy94
Auto: VW GOLF VI
Engine: 2.5L
Localization: Pomorskie
Post autor: Kusy94 »
Mam problem, występuje u mnie błąd jakiś dotyczący silnika, a że jestem zielony to proszę o waszą pomoc w nakierowanie do źródła problemu. Błędu nie idzie wykasować.
Tuesday,07,March,2017,22:36:06:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
http://www.Ross-Tech.com
VIN: WVWAB7AJ6BW225XXX License Plate:
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 77
VIN: WVWAB7AJ6BW225XXX Mileage: 104770km-65101miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 BD HW: 07K 906 055
Component: 2,5l R5/4V G01 8240
Revision: T4H04--- Serial number:
Coding: 0000071
Shop #: WSC 01357 011 00200
VCID: 71E9BFA2686830CA5F-8024
8 Faults Found:
008583 - Bank 1; System too Lean at Idle
P2187 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 99672 km
Time Indication: 0
Date: 2016.10.02
Time: 12:51:27
Freeze Frame:
RPM: 663 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 36.0°C
Absolute Pres.: 990.0 mbar
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2096 - 000 - Too Lean - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 53
Reset counter: 255
Mileage: 101991 km
Time Indication: 0
Date: 2016.12.16
Time: 14:00:44
Freeze Frame:
RPM: 2694 /min
Load: 23.5 %
Speed: 73.0 km/h
Temperature: 88.0°C
Temperature: 13.0°C
Absolute Pres.: 1000.0 mbar
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 102784 km
Time Indication: 0
Date: 2017.01.08
Time: 21:03:00
Freeze Frame:
RPM: 4061 /min
Load: 82.7 %
Speed: 38.0 km/h
Temperature: 65.0°C
Temperature: -1.0°C
000769 - Cylinder 1
P0301 - 000 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 102942 km
Time Indication: 0
Date: 2017.01.15
Time: 17:28:12
Freeze Frame:
RPM: 967 /min
Load: 23.9 %
Speed: 7.0 km/h
Temperature: 62.0°C
Temperature: 3.0°C
000771 - Cylinder 3
P0303 - 000 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 103880 km
Time Indication: 0
Date: 2017.02.14
Time: 18:18:27
Freeze Frame:
RPM: 3665 /min
Load: 74.1 %
Speed: 146.0 km/h
Temperature: 86.0°C
Temperature: 9.0°C
001056 - Catalyst System; Bank 1
P0420 - 000 - Efficiency Below Threshold - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 104153 km
Time Indication: 0
Date: 2017.02.24
Time: 12:08:34
Freeze Frame:
RPM: 2333 /min
Load: 32.5 %
Speed: 93.0 km/h
Temperature: 87.0°C
Temperature: 5.0°C
Absolute Pres.: 970.0 mbar
004874 - Cylinder Disabling
P130A - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 104600 km
Time Indication: 0
Date: 2017.03.01
Time: 08:40:03
Freeze Frame:
RPM: 4049 /min
Load: 99.6 %
Speed: 66.0 km/h
Temperature: 63.0°C
Temperature: 6.0°C
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 19.0°C
Ostatnio zmieniony 08 mar 2017, 23:37 przez marmi, łącznie zmieniany 1 raz.
Powód: uciałem czesc nie zwiazana z silnikiem
stahu
Auto: VW Golf VI
Engine: 1.8 TSI CDAA
Localization: Warszawa
Re: 01-Engine -- Status: Malfunction 0010
Post autor: stahu »
Opisz co się dzieje z autem. Równo pracuje? Dawno temu wymieniane świece?
Kusy94
Auto: VW GOLF VI
Engine: 2.5L
z samochodem chyba wszystko okej.
świece nie mam pojęcia, może warto wymienić.
a reszta błędów oprócz tych z wypadaniem spalania może być spowodowana instalacją LPG?
